Display information about the UDP forwarding characteristics of the device. UDP forwarding only supports 128 entries.
  1. Enter Privileged EXEC mode:
    enable
  2. Display information about the UDP interface for all IP addresses or a specified IP address:
    show ip forward-protocol udp interface [<A.B.C.D>] [vrf WORD<1-16>] [vrfids WORD<0-512>]
  3. Display the UDP port forwarding table:
    show ip forward-protocol udp portfwd [vrf WORD<1-16>] [vrfids WORD<0-512>]
  4. Display the UDP port forwarding list table for the specified list or all lists on the device:
    show ip forward-protocol udp portfwdlist [vrf WORD<1-16>] [vrfids WORD<0-512>]
  5. Display the UDP protocol table with the UDP port numbers for each supported or designated protocol:
    show ip forward-protocol udp [vrf WORD<1-16>] [vrfids WORD<0-512>]
Switch:1>enable
Switch:1#show ip forward-protocol udp
                        Udp Protocol Tbl - GlobalRouter
UDP_PORT PROTOCOL_NAME
37       Time Service
49       TACACS Service
53       DNS
69       TFTP
137      NetBIOS NameSrv
138      NetBIOS DataSrv
Use the data in the following table to use the show ip forward-protocol udp interface command.
Variable
Value
<A.B.C.D>
Specifies the IP address for the interface in a.b.c.d format.
vrf WORD<1–16>
Specifies the name of the VRF.
vrfids WORD<0–512>
Specifies the ID of the VRF and is an integer in the range of 0 to 512.
